Salta al contenuto principale
Glass Door Latch Replacement
Cosa ti serve
  1. Glass Door Latch Replacement, Outer Removal: passo 1, immagine 1 di 3 Glass Door Latch Replacement, Outer Removal: passo 1, immagine 2 di 3 Glass Door Latch Replacement, Outer Removal: passo 1, immagine 3 di 3
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: passo 2, immagine 1 di 3 Glass Door Latch Replacement, Preparation: passo 2, immagine 2 di 3 Glass Door Latch Replacement, Preparation: passo 2, immagine 3 di 3
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: passo 3, immagine 1 di 2 Glass Door Latch Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: passo 4, immagine 1 di 2 Glass Door Latch Replacement, Mechanism Removal: passo 4, immagine 2 di 2
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: passo 5, immagine 1 di 2 Glass Door Latch Replacement, Replacement Prep: passo 5, immagine 2 di 2
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: passo 6, immagine 1 di 3 Glass Door Latch Replacement, Installation: passo 6, immagine 2 di 3 Glass Door Latch Replacement, Installation: passo 6, immagine 3 di 3
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: passo 7, immagine 1 di 3 Glass Door Latch Replacement, Installation Cont.: passo 7, immagine 2 di 3 Glass Door Latch Replacement, Installation Cont.: passo 7, immagine 3 di 3
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: passo 8, immagine 1 di 2 Glass Door Latch Replacement, Latch Correction: passo 8, immagine 2 di 2
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: passo 9, immagine 1 di 3 Glass Door Latch Replacement, Handle Placement: passo 9, immagine 2 di 3 Glass Door Latch Replacement, Handle Placement: passo 9, immagine 3 di 3
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
Conclusione
CJ Cummings
Membro da: 05/04/20
169 Reputazione
1 Guida realizzata
Un commento
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 171
Tutti i Tempi: 6,631
