Salta al contenuto principale
Glade Automatic Spray Holder SJC-180 Motor Replacement
Cosa ti serve
  1. Glade Automatic Spray Holder SJC-180 Motor Replacement, Battery Terminal: passo 1, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement, Battery Terminal: passo 1, immagine 2 di 2
    • Press the button labelled glade to open the housing.
    • The inside of the holder has the timer switch and the covering for the inner workings of the holder. For this project, you only need to worry about the battery area located behind the spray.
    • Locate the timer switch and slide it to off.
    • This will prevent any accidental sprays into your face before you remove the spray canister.
  2. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 2, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 2, immagine 2 di 2
    • Remove the spray canister to expose the batteries.
  3. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 3, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 3, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 3, immagine 3 di 3
    • Squeeze and remove the bottom of the front cover. This makes troubleshooting and repairing easier.
    • Pop one side of the hinge from its peg and slightly pull it away from the device.
    • Do the same with the opposite side of the device. Removing the cover will make it easier to work.
  4. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 4, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 4, immagine 2 di 2
    • Remove the batteries to expose the terminals. The terminals are the thin metal pieces that hold the batteries in place.
    • Without the batteries, you can visually assess for problems like loose wires.
  5. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 5, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 5, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 5, immagine 3 di 3
    • Use small needle nose pliers to gently remove each terminal. Check if any wires are disconnected or loose.
    • The terminals with negative connections (black wires) could have breaks or might have detached from the terminal base. Check for additional issues.
    • The bottom terminal is one piece instead of two pieces like the top ones.
  6. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 6, immagine 1 di 1
    • Use the soldering gun and soldering electrical wire to solder the bared wire to the terminal.
    • Make sure your fingers are a safe distance away from the soldering rod and from the component you are fixing. Use pliers to hold the terminal still.
  7. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 7, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 7, immagine 2 di 2
    • The solder does not need to be beautiful, just functional.
    • Put the fixed terminal back into the correct place to hold the batteries.
  8. Glade Automatic Spray Holder SJC-180 Motor Replacement, Circuit Board: passo 8, immagine 1 di 1
  9. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 9, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 9, immagine 2 di 2
    • There are 4 screws that need to be removed to expose the inner components (such as the motor). Use a Phillips head screwdriver to remove the screws. Gently pull the screws straight out to avoid disrupting the components you are exposing.
    • Once the cover is removed, take a picture to reference when you're reassembling the device. The larger electrical board is on the top. The plastic gears are easily moved out of their positions when removing cover and board.
  10. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 10, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 10, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 10, immagine 3 di 3
    • The first circuit board to inspect has the timer switch on it. This circuit board is the larger of the two that are part of the device.
    • The circuit board is held in place by 3 pegs. The pegs are plastic. This means you do not need special tools to remove the circuit board. It will pop off using your fingers.
    • Flip the board over to look for loose wires or any burnt spots. This one is okay.
  11. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 11, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 11, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 11, immagine 3 di 3
    • It is best to remove plastic gears before flipping the plastic plate holding everything together. The gears will fall out. Start with the fan shape gear. No tools needed; each gear is held into place by pegs.
    • Next is the largest gear. It is centrally located.
    • Last is the medium size gear. Located towards the bottom left.
  12. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 12, immagine 1 di 2 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 12, immagine 2 di 2
    • Next locate the small circuit board. Red arrows indicate where the wires are connected to the board.
    • Once pulled off the 2 pegs holding the small circuit board, the red wire came off of the board.
  13. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 13, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 13, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 13, immagine 3 di 3
    • Solder the red wire back to the correct point on the circuit board. You'll be able to see the original factory solder point close to the edge of the board. It will be next to the black wire.
    • Once done with the solder, wait until it has cooled and pull gently to verify that it is securely attached to the circuit board.
    • Finished the circuit board and wire reattachment.
  14. Glade Automatic Spray Holder SJC-180 Motor Replacement, Motor: passo 14, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement, Motor: passo 14, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement, Motor: passo 14, immagine 3 di 3
    • Once you follow the perquisites, locate the motor. It is metal with a blue top. A red wire and a black wire are attached to the blue top.
    • Flip the plastic plate holding the motor upside down and locate the 2 screws securing the motor to the plate.
    • Use a small Phillips head screwdriver to remove the screws. This will free the motor from the plate.
  15. Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 15, immagine 1 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 15, immagine 2 di 3 Glade Automatic Spray Holder SJC-180 Motor Replacement: passo 15, immagine 3 di 3
    • Cut the wires away from the old motor using the needle nose plier wire cutter, located next to the plier hinge (as seen in the red circle).
    • Attach the red wire to the new motor with the soldering iron and solder. The red wire will go to the left side of the motor face with a metal strip on the blue part.
    • Repeat with the black wire to the right side of the motor.
    • Once the wires are attached to the new motor, slide the new motor into the old motor's place.
    • Once the new new motor is in place, use the two screws mentioned in step 1 to secure the motor into place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 42
Tutti i Tempi: 653
