Salta al contenuto principale
Giant Talon 29er Chainring Replacement
Cosa ti serve
  1. Giant Talon 29er Chainring Replacement, Chainring: passo 1, immagine 1 di 3 Giant Talon 29er Chainring Replacement, Chainring: passo 1, immagine 2 di 3 Giant Talon 29er Chainring Replacement, Chainring: passo 1, immagine 3 di 3
    • Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
    • Unroute the chain from the chainrings.
  2. Giant Talon 29er Chainring Replacement: passo 2, immagine 1 di 1
    • Remove the 8 mm Hex screw from the crank arm.
  3. Giant Talon 29er Chainring Replacement: passo 3, immagine 1 di 1
    • Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
  4. Giant Talon 29er Chainring Replacement: passo 4, immagine 1 di 1
    • Remove the four 5 mm Hex screws that mount the crank arm to the chainrings.
  5. Giant Talon 29er Chainring Replacement: passo 5, immagine 1 di 3 Giant Talon 29er Chainring Replacement: passo 5, immagine 2 di 3 Giant Talon 29er Chainring Replacement: passo 5, immagine 3 di 3
    • Rotate the largest chainring 45 degrees in either direction.
    • Remove the crank arm from the chainrings.
Conclusione
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
Ben Frisbie
Membro da: 03/22/16
209 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,422
