Salta al contenuto principale
Giant Reign 2 Front Wheel Replacement
Cosa ti serve
  1. Giant Reign 2 Front Wheel Replacement, Hex Screws: passo 1, immagine 1 di 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Front Wheel Replacement, Axle Screw: passo 2, immagine 1 di 2 Giant Reign 2 Front Wheel Replacement, Axle Screw: passo 2, immagine 2 di 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Front Wheel Replacement: passo 3, immagine 1 di 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Front Wheel Replacement, Front Wheel: passo 4, immagine 1 di 1
    • Pull the wheel from the fork.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 9-14, Amido Fall 2012 Membro di Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 128
Tutti i Tempi: 12,898
