Salta al contenuto principale
Ghost Longboard Wheel Replacement
Cosa ti serve
  1. Ghost Longboard Wheel Replacement, Wheel: passo 1, immagine 1 di 1
    • Using a 15 mm socket wrench, unscrew the axle nut.
  2. Ghost Longboard Wheel Replacement: passo 2, immagine 1 di 1
    • Using your fingers, remove the axle nut from the axle.
  3. Ghost Longboard Wheel Replacement: passo 3, immagine 1 di 1
    • Remove the washer from the axle.
  4. Ghost Longboard Wheel Replacement: passo 4, immagine 1 di 1
    • Remove the wheel from the axle.
  5. Ghost Longboard Wheel Replacement: passo 5, immagine 1 di 1
    • Remove the second washer from the axle.
  6. Ghost Longboard Wheel Replacement: passo 6, immagine 1 di 1
    • Slide a new washer onto the axle.
  7. Ghost Longboard Wheel Replacement: passo 7, immagine 1 di 2 Ghost Longboard Wheel Replacement: passo 7, immagine 2 di 2
    • Place the new wheel on the axle.
    • Be sure to position the flat side of the wheel so it is facing inward.
  8. Ghost Longboard Wheel Replacement: passo 8, immagine 1 di 1
    • Place a second washer on the axle exterior to the wheel.
  9. Ghost Longboard Wheel Replacement: passo 9, immagine 1 di 1
    • Place an axle nut on the axle.
  10. Ghost Longboard Wheel Replacement: passo 10, immagine 1 di 1
    • Using a 15 mm socket wrench, tighten the axle nut.
    • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
Conclusione
Repeat these steps on the three remaining wheels.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 385
