Salta al contenuto principale
Getting randomly stuck at 100% input
Cosa ti serve
  1. Getting randomly stuck at 100% input, Perform Maintenance: passo 1, immagine 1 di 1
    • You can find a guide on how to perform that here.
  2. Getting randomly stuck at 100% input, Remove your carpet: passo 2, immagine 1 di 1
    • If you have a carpet underneath your setup, remove it.
    • If the carpet is built into the floor, buy an anti-static floor mat to fit underneath your setup.
    • Create a path from your rig or pedals to Earth, so that static electricity would dissipate through it.
    • Not all homes have grounding built-in. You may need to get creative or create grounding yourself.
    • Understanding the ESD is important. Read more about it here, here and here.
Conclusione
Eliminating possibility of Electro-Static Discharge will prevent your pedal getting randomly stuck at 100% or 50% input.
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 26
Tutti i Tempi: 199
