Salta al contenuto principale
Getac V110 Battery Replacement
Cosa ti serve
  1. Getac V110 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your laptop and unplug it from any power source.
  2. Getac V110 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the battery of your Getac V110.
    • There are two doors, one for the right battery and another for the left battery.
  3. Getac V110 Battery Replacement: passo 3, immagine 1 di 3 Getac V110 Battery Replacement: passo 3, immagine 2 di 3 Getac V110 Battery Replacement: passo 3, immagine 3 di 3
    • Gain access to battery by : Sliding the lock to right.
    • Folding the lock down.
    • Move battery strap to right.
  4. Getac V110 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the old battery by sliding it out of its slot.
  5. Getac V110 Battery Replacement: passo 5, immagine 1 di 3 Getac V110 Battery Replacement: passo 5, immagine 2 di 3 Getac V110 Battery Replacement: passo 5, immagine 3 di 3
    • Slide the new battery into the same slot where the old one was.
    • Reminder: Attach the battery door back in place.
    • Reminder: Secure it with it's locks.
  6. Getac V110 Battery Replacement: passo 6, immagine 1 di 1
    • If you’re replacing both batteries, repeat the same steps for the other side.
  7. Getac V110 Battery Replacement: passo 7, immagine 1 di 1
    • Power on your laptop and check if it recognizes the new battery.
    • Reminder: Monitor the battery health to ensure it’s charging properly.
Conclusione
With the new battery installed, power up your Getac V110 and enjoy extended use without worrying about running out of juice. If you followed the guide carefully, the replacement process should be quick and painless. Now get back to work with your fully functional laptop!
Anthony's Team Membro di Anthony's Team
Community
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 60
Tutti i Tempi: 280
