Introduzione
It is shown step by step the complete disassembly of the device. Since there was no sign of life any more, I took it apart. The problem was finally a loose plug, which stopped the power supply of the device. The example shown here is unfortunately broken off from the outer shell, but this should not change the procedure.
Cosa ti serve
Remove the battery by prying up the rear cover on the two slots
Disconnect charger (5.5V 2A)
With a PH1 screwdriver, the two remaining screws which hold the two larger boards arranged above each other can be removed.
The flat white plugs can be removed with a screwdriver from the board.
The width on the left edge of the device is held in place with a brown clip that can be easily pulled out. Thereafter, the flat cable is directly loose.
The assembly is actually the same backwards.
Clean the area around the controls THOROUGHLY because they are otherwise always "activated".
Repeat the steps in order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
