1. remove all 8 screws remove all 3 screws THIS COVER COMES OFF AS ONE PIECE BE CAREFUL AS IT BREAKS EASILY.
    • remove all 8 screws
    • remove all 3 screws
    • THIS COVER COMES OFF AS ONE PIECE BE CAREFUL AS IT BREAKS EASILY.
  2. Cut Zip Tie. Remember its location and use this photo for reference This harness needs to be separate by simply peeling back the Velcro sleeve
    • Cut Zip Tie. Remember its location and use this photo for reference
    • This harness needs to be separate by simply peeling back the Velcro sleeve
  3. Remove all 4 bolts top will separate from bottom at this point. TAKE CARE BECAUSE TOP AND BOTTOM ARE STILL CONNECTED VIA WIRES AND HOSES .
    • Remove all 4 bolts
    • top will separate from bottom at this point.
    • TAKE CARE BECAUSE TOP AND BOTTOM ARE STILL CONNECTED VIA WIRES AND HOSES .
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the 2 screws from the lower detection sensor. you can leave this sensor hanging, but just take care and remember its there . Remove all 4 bolts
    • Remove the 2 screws from the lower detection sensor.
    • you can leave this sensor hanging, but just take care and remember its there .
    • ONCE THESE BOLTS ARE REMOVED THE FRAME WILL DROP BE SURE YOU ARE READY TO CATCH IT.
    • TAKE NOTE OF THE SCREW POSITIONING. THIS WILL COME INTO PLAY WHEN REASSEMBLING
  6. Manually move the motor by spinning the belt to the RIGHT. Now the footrest Frame should look like this by now. Fully Extended  out.
    • Manually move the motor by spinning the belt to the RIGHT.
    • Now the footrest Frame should look like this by now. Fully Extended out.
  7. On the top of the Box there is 4 small silver nuts that thread inter a longer screw that are mounted on the back of this frame. Using a Philips head screw driver and vice grips or proper sizes spanner . You can apply force on the screws while while holding the nut in place with your spanner or vice grips. IF YOU OPT TO USE VICE GRIPS BE CAREFUL AS THEY CAN BEND THE NUT CREATING  A MORE DIFFICULT SITUATION.
    • On the top of the Box there is 4 small silver nuts that thread inter a longer screw that are mounted on the back of this frame.
    • Using a Philips head screw driver and vice grips or proper sizes spanner . You can apply force on the screws while while holding the nut in place with your spanner or vice grips.
    • IF YOU OPT TO USE VICE GRIPS BE CAREFUL AS THEY CAN BEND THE NUT CREATING A MORE DIFFICULT SITUATION.
  8. Once the plastic Guide has has all screws removed go ahead firmly grab the extend track and gently lift up on it while spinning the box off the track.
    • Once the plastic Guide has has all screws removed go ahead firmly grab the extend track and gently lift up on it while spinning the box off the track.
Conclusione
Nick
Membro da: 30/05/2017
2.593 Reputazione
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 10
