Salta al contenuto principale
Generic TV Remote IR LED Replacement
Cosa ti serve
  1. Generic TV Remote IR LED Replacement, IR LED: passo 1, immagine 1 di 2 Generic TV Remote IR LED Replacement, IR LED: passo 1, immagine 2 di 2
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
  2. Generic TV Remote IR LED Replacement: passo 2, immagine 1 di 3 Generic TV Remote IR LED Replacement: passo 2, immagine 2 di 3 Generic TV Remote IR LED Replacement: passo 2, immagine 3 di 3
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
  3. Generic TV Remote IR LED Replacement: passo 3, immagine 1 di 1
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
  4. Generic TV Remote IR LED Replacement: passo 4, immagine 1 di 1
    • Desolder the broken LED using a soldering iron and desoldering braid.
  5. Generic TV Remote IR LED Replacement: passo 5, immagine 1 di 1
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
  6. Generic TV Remote IR LED Replacement: passo 6, immagine 1 di 3 Generic TV Remote IR LED Replacement: passo 6, immagine 2 di 3 Generic TV Remote IR LED Replacement: passo 6, immagine 3 di 3
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
  7. Generic TV Remote IR LED Replacement: passo 7, immagine 1 di 1
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 73
Tutti i Tempi: 14,533
