Introduzione
In order to gain access to the interior of the camera, this step will show how to remove the interior frame and the button control board.
Cosa ti serve
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
Altre 2 persone hanno completato questa guida.
