Salta al contenuto principale
General Disassembly LG VX8560
Cosa ti serve
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: passo 1, immagine 1 di 1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: passo 2, immagine 1 di 1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: passo 3, immagine 1 di 1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: passo 4, immagine 1 di 1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: passo 5, immagine 1 di 2 General Disassembly LG VX8560: passo 5, immagine 2 di 2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: passo 6, immagine 1 di 1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Conclusione
Jack Foley
Membro da: 04/25/13
37 Reputazione
3 Guide realizzate
Cal Poly, Team 13-62, Johann Spring 2013 Membro di Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Membri
12 Guide realizzate
Un commento
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 398
