Salta al contenuto principale
GeeksPhone Keon Motherboard Replacement
Cosa ti serve
  1. GeeksPhone Keon Motherboard Replacement, Battery: passo 1, immagine 1 di 2 GeeksPhone Keon Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Motherboard Replacement: passo 2, immagine 1 di 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Motherboard Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon Motherboard Replacement, Back Plate: passo 4, immagine 1 di 2 GeeksPhone Keon Motherboard Replacement, Back Plate: passo 4, immagine 2 di 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon Motherboard Replacement: passo 5, immagine 1 di 2 GeeksPhone Keon Motherboard Replacement: passo 5, immagine 2 di 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon Motherboard Replacement: passo 7, immagine 1 di 3 GeeksPhone Keon Motherboard Replacement: passo 7, immagine 2 di 3 GeeksPhone Keon Motherboard Replacement: passo 7, immagine 3 di 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon Motherboard Replacement: passo 8, immagine 1 di 2 GeeksPhone Keon Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon Motherboard Replacement, Motherboard: passo 9, immagine 1 di 2 GeeksPhone Keon Motherboard Replacement, Motherboard: passo 9, immagine 2 di 2
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
  10. GeeksPhone Keon Motherboard Replacement: passo 10, immagine 1 di 1
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
  11. GeeksPhone Keon Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard from the device.
Conclusione
USF Tampa, Team 3-5, Eyestone Fall 2015 Membro di USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 172
