Salta al contenuto principale
Gateway W350I RAM Replacement
Cosa ti serve
  1. Gateway W350I RAM Replacement, Battery Access: passo 1, immagine 1 di 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I RAM Replacement, Unlocking the Battery: passo 2, immagine 1 di 3 Gateway W350I RAM Replacement, Unlocking the Battery: passo 2, immagine 2 di 3 Gateway W350I RAM Replacement, Unlocking the Battery: passo 2, immagine 3 di 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I RAM Replacement, Remove Bottom Cover: passo 3, immagine 1 di 3 Gateway W350I RAM Replacement, Remove Bottom Cover: passo 3, immagine 2 di 3 Gateway W350I RAM Replacement, Remove Bottom Cover: passo 3, immagine 3 di 3
    • Turn the laptop over to remove the plastic cover.
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I RAM Replacement, Removing RAM Chips: passo 4, immagine 1 di 3 Gateway W350I RAM Replacement, Removing RAM Chips: passo 4, immagine 2 di 3 Gateway W350I RAM Replacement, Removing RAM Chips: passo 4, immagine 3 di 3
    • Gently pull the first RAM chip to slide it free from the mounting on the board.
    • Gently pull the second RAM chip, located under the first, to slide it free from the mounting on the board.
Conclusione
Aaron Austin
Membro da: 09/22/14
249 Reputazione
2 Guide realizzate
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,740
