Salta al contenuto principale
Gateway W350I Heatsink Fan Replacement
Cosa ti serve
  1. Gateway W350I Heatsink Fan Replacement, Battery Access: passo 1, immagine 1 di 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, immagine 1 di 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, immagine 2 di 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: passo 2, immagine 3 di 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, immagine 1 di 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, immagine 2 di 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: passo 3, immagine 3 di 3
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, immagine 1 di 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, immagine 2 di 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: passo 4, immagine 3 di 3
    • Remove all four 3mm Phillips #0 screws holding in the fan.
    • Remove the tape from the top of the fan
  5. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, immagine 1 di 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, immagine 2 di 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: passo 5, immagine 3 di 3
    • Gently remove the fan from the metal housing.
    • Disconnect the cable with tweezers.
Conclusione
Aaron Austin
Membro da: 09/22/14
249 Reputazione
2 Guide realizzate
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 996
