Salta al contenuto principale
Gateway W350I Display Replacement
Cosa ti serve
  1. Gateway W350I Display Replacement, Battery Access: passo 1, immagine 1 di 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 1 di 3 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 2 di 3 Gateway W350I Display Replacement, Unlocking the Battery: passo 2, immagine 3 di 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, immagine 1 di 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: passo 3, immagine 2 di 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, immagine 1 di 2 Gateway W350I Display Replacement, Separate Plastic Casing: passo 4, immagine 2 di 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, immagine 1 di 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: passo 5, immagine 2 di 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: passo 6, immagine 1 di 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: passo 7, immagine 1 di 2 Gateway W350I Display Replacement, Remove Video Cable: passo 7, immagine 2 di 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: passo 8, immagine 1 di 2 Gateway W350I Display Replacement: passo 8, immagine 2 di 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
Conclusione
Altre 3 persone hanno completato questa guida.
Samuel Newton
Membro da: 09/22/14
296 Reputazione
1 Guida realizzata
USF Tampa, Team 4-1, Brown Fall 2014 Membro di USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Membri
10 Guide realizzate
Un commento
It was very easy to follow.
Very friendly guide.
Stephan Williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,260
