Salta al contenuto principale
Gateway Solo 1200 Keyboard and Frame Replacement
Cosa ti serve
  1. Gateway Solo 1200 Keyboard and Frame Replacement, Battery: passo 1, immagine 1 di 3 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: passo 1, immagine 2 di 3 Gateway Solo 1200 Keyboard and Frame Replacement, Battery: passo 1, immagine 3 di 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: passo 2, immagine 1 di 2 Gateway Solo 1200 Keyboard and Frame Replacement, Keyboard and Frame: passo 2, immagine 2 di 2
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Keyboard and Frame Replacement: passo 3, immagine 1 di 2 Gateway Solo 1200 Keyboard and Frame Replacement: passo 3, immagine 2 di 2
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Keyboard and Frame Replacement: passo 4, immagine 1 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 4, immagine 2 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 4, immagine 3 di 3
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Keyboard and Frame Replacement: passo 5, immagine 1 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 5, immagine 2 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 5, immagine 3 di 3
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Keyboard and Frame Replacement: passo 6, immagine 1 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 6, immagine 2 di 3 Gateway Solo 1200 Keyboard and Frame Replacement: passo 6, immagine 3 di 3
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 300
