Salta al contenuto principale
Gateway Solo 1200 Battery Replacement
  1. Gateway Solo 1200 Battery Replacement, Battery: passo 1, immagine 1 di 3 Gateway Solo 1200 Battery Replacement, Battery: passo 1, immagine 2 di 3 Gateway Solo 1200 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 352
