Salta al contenuto principale
Gateway SA1 RAM Replacement
Cosa ti serve
  1. Gateway SA1 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 RAM Replacement: passo 2, immagine 1 di 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 RAM Replacement, RAM: passo 3, immagine 1 di 2 Gateway SA1 RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
  4. Gateway SA1 RAM Replacement: passo 4, immagine 1 di 2 Gateway SA1 RAM Replacement: passo 4, immagine 2 di 2
    • Lift and remove the cover using the spudger.
  5. Gateway SA1 RAM Replacement: passo 5, immagine 1 di 2 Gateway SA1 RAM Replacement: passo 5, immagine 2 di 2
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
  6. Gateway SA1 RAM Replacement: passo 6, immagine 1 di 1
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 24-20, Regan Spring 2010 Membro di Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,740
