Salta al contenuto principale
Gateway SA1 Outer Casing Replacement
Cosa ti serve
  1. Gateway SA1 Outer Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Move the latch to the right of the battery to unlock.
    Chiedi a FixBot
    Aggiungi Commento
  2. Gateway SA1 Outer Casing Replacement: passo 2, immagine 1 di 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Gateway SA1 Outer Casing Replacement, Disk Drive: passo 3, immagine 1 di 1
    • Unscrew the marked 5.9 mm Philips screw.
    Chiedi a FixBot
    Aggiungi Commento
  4. Gateway SA1 Outer Casing Replacement: passo 4, immagine 1 di 1
    • Use the spudger to pry out the Disk dive.
    Chiedi a FixBot
    Aggiungi Commento
  5. Gateway SA1 Outer Casing Replacement: passo 5, immagine 1 di 1
    • The disk drive should easily detach and can now be replaced.
    Chiedi a FixBot
    Aggiungi Commento
  6. Gateway SA1 Outer Casing Replacement, Outer Casing: passo 6, immagine 1 di 1
    • Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove one 8.8 mm Philips screw from the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. Gateway SA1 Outer Casing Replacement: passo 7, immagine 1 di 3 Gateway SA1 Outer Casing Replacement: passo 7, immagine 2 di 3 Gateway SA1 Outer Casing Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
    • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
    Chiedi a FixBot
    Aggiungi Commento
  8. Gateway SA1 Outer Casing Replacement: passo 8, immagine 1 di 2 Gateway SA1 Outer Casing Replacement: passo 8, immagine 2 di 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
    Chiedi a FixBot
    Aggiungi Commento
  9. Gateway SA1 Outer Casing Replacement: passo 9, immagine 1 di 3 Gateway SA1 Outer Casing Replacement: passo 9, immagine 2 di 3 Gateway SA1 Outer Casing Replacement: passo 9, immagine 3 di 3
    • There will be a connection underneath the speaker cover.
    • Remove the speaker cover using the spudger.
    Chiedi a FixBot
    Aggiungi Commento
  10. Gateway SA1 Outer Casing Replacement: passo 10, immagine 1 di 1
    • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. Gateway SA1 Outer Casing Replacement: passo 11, immagine 1 di 3 Gateway SA1 Outer Casing Replacement: passo 11, immagine 2 di 3 Gateway SA1 Outer Casing Replacement: passo 11, immagine 3 di 3
    • Carefully lift the keyboard off from the laptop. It is still attached as shown.
    • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
    • The brown colored component with the tabs does not come out with the connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. Gateway SA1 Outer Casing Replacement: passo 12, immagine 1 di 3 Gateway SA1 Outer Casing Replacement: passo 12, immagine 2 di 3 Gateway SA1 Outer Casing Replacement: passo 12, immagine 3 di 3
    • Lift up the black tab and gently pull out the connector.
    Chiedi a FixBot
    Aggiungi Commento
  13. Gateway SA1 Outer Casing Replacement: passo 13, immagine 1 di 2 Gateway SA1 Outer Casing Replacement: passo 13, immagine 2 di 2
    • Unscrew the four marked 5.9 mm Philips screws.
    Chiedi a FixBot
    Aggiungi Commento
  14. Gateway SA1 Outer Casing Replacement: passo 14, immagine 1 di 2 Gateway SA1 Outer Casing Replacement: passo 14, immagine 2 di 2
    • Move the wires out of the fixed space as shown.
    Chiedi a FixBot
    Aggiungi Commento
  15. Gateway SA1 Outer Casing Replacement: passo 15, immagine 1 di 2 Gateway SA1 Outer Casing Replacement: passo 15, immagine 2 di 2
    • Unscrew the five marked 3.8 mm Philips screws.
    • Three screws are located on the right side of the screen.
    • Two screws are located on the left side of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  16. Gateway SA1 Outer Casing Replacement: passo 16, immagine 1 di 1
    • Remove the screen brackets from the computer's base.
    Chiedi a FixBot
    Aggiungi Commento
  17. Gateway SA1 Outer Casing Replacement: passo 17, immagine 1 di 3 Gateway SA1 Outer Casing Replacement: passo 17, immagine 2 di 3 Gateway SA1 Outer Casing Replacement: passo 17, immagine 3 di 3
    • Remove the four 5.9 mm Philips screws as indicated:
    • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
    • There are two similarly positioned screws on the right side.
    Chiedi a FixBot
    Aggiungi Commento
  18. Gateway SA1 Outer Casing Replacement: passo 18, immagine 1 di 2 Gateway SA1 Outer Casing Replacement: passo 18, immagine 2 di 2
    • The following steps (18 - 20) explain how to remove the three indicated connections.
    • The order is Blue, Violet, Orange.
    • Lift the white tab up and gently take out the connector.
    Chiedi a FixBot
    Aggiungi Commento
  19. Gateway SA1 Outer Casing Replacement: passo 19, immagine 1 di 1
    • Use the spudger to pull off the black attachment.
    Chiedi a FixBot
    Aggiungi Commento
  20. Gateway SA1 Outer Casing Replacement: passo 20, immagine 1 di 1
    • Lift and pull the black tab upward until it becomes unattached.
    • Some force may be required.
    Chiedi a FixBot
    Aggiungi Commento
  21. Gateway SA1 Outer Casing Replacement: passo 21, immagine 1 di 1
    • Use the spudger to remove the casing as seen in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  22. Gateway SA1 Outer Casing Replacement: passo 22, immagine 1 di 1
    • Remove the casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 24-20, Regan Spring 2010 Membro di Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 17
Ultimi 30 giorni: 48
Tutti i Tempi: 16,446
