Salta al contenuto principale
Gateway SA1 Hard Drive Replacement
Cosa ti serve
  1. Gateway SA1 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: passo 4, immagine 1 di 2 Gateway SA1 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: passo 5, immagine 1 di 2 Gateway SA1 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 24-20, Regan Spring 2010 Membro di Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 61
Tutti i Tempi: 13,576
