Salta al contenuto principale
Gateway SA1 Cooling Fan Replacement
Cosa ti serve
  1. Gateway SA1 Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 2 Gateway SA1 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: passo 5, immagine 1 di 2 Gateway SA1 Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: passo 7, immagine 1 di 1
    • You are now able to remove the cooling fan.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 24-20, Regan Spring 2010 Membro di Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 77
Tutti i Tempi: 13,835
