Salta al contenuto principale
Gateway P-7805u Hard Drive Replacement
Cosa ti serve
  1. Gateway P-7805u Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Unscrew all .5mm screws from the back rectangular panel. Use a J0 screwdriver.
    • Screws will not come out all the way out. Simply unscrew until they do not come out any further.
  2. Gateway P-7805u Hard Drive Replacement: passo 2, immagine 1 di 2 Gateway P-7805u Hard Drive Replacement: passo 2, immagine 2 di 2
    • Firmly press with your hand on the silver surface and pull back, dislodging the hard drive from its port.
  3. Gateway P-7805u Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the four 1.2mm screws attaching the case to the hard drive. Use the same J0 screwdriver.
  4. Gateway P-7805u Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pull out the old hard drive.
Conclusione
Baylor, Team S8-G6, Johnson Fall 2017 Membro di Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 244
