Salta al contenuto principale
Gateway P-7805u Battery Replacement
Cosa ti serve
  1. Gateway P-7805u Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Be sure the laptop is turned off.
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the switch to the right of the battery. Unlock this switch by pushing it to the right.
  2. Gateway P-7805u Battery Replacement: passo 2, immagine 1 di 1
    • Pull the battery pack out of its slot.
Conclusione
Baylor, Team S8-G6, Johnson Fall 2017 Membro di Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 243
