Salta al contenuto principale
Gateway P-6831FX WiFi Card Replacement
Cosa ti serve
  1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: passo 1, immagine 1 di 2 Gateway P-6831FX WiFi Card Replacement, WiFi Card: passo 1, immagine 2 di 2
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
    • Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
  2. Gateway P-6831FX WiFi Card Replacement: passo 2, immagine 1 di 2 Gateway P-6831FX WiFi Card Replacement: passo 2, immagine 2 di 2
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX WiFi Card Replacement: passo 3, immagine 1 di 3 Gateway P-6831FX WiFi Card Replacement: passo 3, immagine 2 di 3 Gateway P-6831FX WiFi Card Replacement: passo 3, immagine 3 di 3
    • Remove the three wires above the WiFi Card.
    • Take note of the color for each wire and it's corresponding location.
  4. Gateway P-6831FX WiFi Card Replacement: passo 4, immagine 1 di 3 Gateway P-6831FX WiFi Card Replacement: passo 4, immagine 2 di 3 Gateway P-6831FX WiFi Card Replacement: passo 4, immagine 3 di 3
    • Remove the two Phillips #0 (2mm) screws above the WiFi card.
    • The WiFi Card will lift up once the screws are removed.
  5. Gateway P-6831FX WiFi Card Replacement: passo 5, immagine 1 di 2 Gateway P-6831FX WiFi Card Replacement: passo 5, immagine 2 di 2
    • With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 425
