Salta al contenuto principale
Gateway P-6831FX Heatsink Replacement
Cosa ti serve
  1. Gateway P-6831FX Heatsink Replacement, Heatsink: passo 1, immagine 1 di 2 Gateway P-6831FX Heatsink Replacement, Heatsink: passo 1, immagine 2 di 2
    • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the Heatsink.
    • Make sure to unplug your laptop charger, as removing the Heatsink while the device is charging may damage the Heatsink and or the charger.
  2. Gateway P-6831FX Heatsink Replacement: passo 2, immagine 1 di 1
    • Gently pull the cover away from the device.
  3. Gateway P-6831FX Heatsink Replacement: passo 3, immagine 1 di 2 Gateway P-6831FX Heatsink Replacement: passo 3, immagine 2 di 2
    • Remove the five Phillips #0 (5mm) screws around the Heatsink.
  4. Gateway P-6831FX Heatsink Replacement: passo 4, immagine 1 di 2 Gateway P-6831FX Heatsink Replacement: passo 4, immagine 2 di 2
    • Gently pull the Heatsink up and away from the chassis.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 217
