Salta al contenuto principale
Gateway P-6831FX Hard Drive Replacement
Cosa ti serve
  1. Gateway P-6831FX Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Gateway P-6831FX Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
    • Make sure to unplug your laptop charger, as removing the hard drive while the device is charging may damage the hard drive and or the charger.
  2. Gateway P-6831FX Hard Drive Replacement: passo 2, immagine 1 di 2 Gateway P-6831FX Hard Drive Replacement: passo 2, immagine 2 di 2
    • Gently pull the cover away from the device.
    • Set the cover aside for now, until reassembly.
  3. Gateway P-6831FX Hard Drive Replacement: passo 3, immagine 1 di 2 Gateway P-6831FX Hard Drive Replacement: passo 3, immagine 2 di 2
    • Pull the plastic tab as shown to remove the hard drive from the device.
  4. Gateway P-6831FX Hard Drive Replacement: passo 4, immagine 1 di 2 Gateway P-6831FX Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
  5. Gateway P-6831FX Hard Drive Replacement: passo 5, immagine 1 di 3 Gateway P-6831FX Hard Drive Replacement: passo 5, immagine 2 di 3 Gateway P-6831FX Hard Drive Replacement: passo 5, immagine 3 di 3
    • Remove the hard drive from the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 295
