Salta al contenuto principale
Gateway P-6831FX Battery Replacement
  1. Gateway P-6831FX Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn your laptop upside down and locate the 1st unlocking switch.
    • Make sure to unplug your laptop charger, as removing the battery while the device is charging may damage the battery and or the charger.
  2. Gateway P-6831FX Battery Replacement: passo 2, immagine 1 di 2 Gateway P-6831FX Battery Replacement: passo 2, immagine 2 di 2
    • Put the switch from the locked position to the unlocked position.
  3. Gateway P-6831FX Battery Replacement: passo 3, immagine 1 di 2 Gateway P-6831FX Battery Replacement: passo 3, immagine 2 di 2
    • Slide the lock to the right to unlock the battery from the device.
  4. Gateway P-6831FX Battery Replacement: passo 4, immagine 1 di 2 Gateway P-6831FX Battery Replacement: passo 4, immagine 2 di 2
    • While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
Conclusione
Justin Freitas
Membro da: 03/19/18
294 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 250
