Salta al contenuto principale
Gateway NV55C49u USB Port Replacement
Cosa ti serve
  1. Gateway NV55C49u USB Port Replacement, USB Port: passo 1, immagine 1 di 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u USB Port Replacement: passo 2, immagine 1 di 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u USB Port Replacement: passo 3, immagine 1 di 2 Gateway NV55C49u USB Port Replacement: passo 3, immagine 2 di 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u USB Port Replacement: passo 4, immagine 1 di 2 Gateway NV55C49u USB Port Replacement: passo 4, immagine 2 di 2
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  5. Gateway NV55C49u USB Port Replacement: passo 5, immagine 1 di 1
    • Remove all nine 6.0mm #00 Phillips screws from the back of the laptop.
  6. Gateway NV55C49u USB Port Replacement: passo 6, immagine 1 di 1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u USB Port Replacement: passo 7, immagine 1 di 1
    • Flip the laptop over so that the cover faces you.
    • Open the laptop so you can see the keyboard.
  8. Gateway NV55C49u USB Port Replacement: passo 8, immagine 1 di 1
    • Push in the tabs that are located around the keyboard using the triangle scalpel tool.
    • This should release the keyboard so it can be pulled up
  9. Gateway NV55C49u USB Port Replacement: passo 9, immagine 1 di 1
    • Slowly lift up the keyboard away from the laptop.
    • Push on the sides on the black ribbon cable using 2 plastic opening tools to release it.
  10. Gateway NV55C49u USB Port Replacement: passo 10, immagine 1 di 1
    • Remove the 3 ribbon cables that are showing using the plastic opening tools.
  11. Gateway NV55C49u USB Port Replacement: passo 11, immagine 1 di 2 Gateway NV55C49u USB Port Replacement: passo 11, immagine 2 di 2
    • Remove the disk drive cover on the right side of the laptop using the plastic opening tool.
    • Slide the disc drive out of its compartment, using the metal spudger.
  12. Gateway NV55C49u USB Port Replacement: passo 12, immagine 1 di 1
    • Lift the face plate off the laptop body.
  13. Gateway NV55C49u USB Port Replacement: passo 13, immagine 1 di 1
    • Remove the 6.0 mm Phillips #00 screw that holds in the USB port.
  14. Gateway NV55C49u USB Port Replacement: passo 14, immagine 1 di 1
    • Push on the sides of the white ribbon cable that is attached to the motherboard using the 2 plastic opening tools to release it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 730
