Salta al contenuto principale
Gateway NV55C49u RAM Replacement
Cosa ti serve
  1. Gateway NV55C49u RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u RAM Replacement: passo 2, immagine 1 di 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u RAM Replacement: passo 3, immagine 1 di 2 Gateway NV55C49u RAM Replacement: passo 3, immagine 2 di 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery.
  4. Gateway NV55C49u RAM Replacement: passo 4, immagine 1 di 1
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u RAM Replacement: passo 5, immagine 1 di 3 Gateway NV55C49u RAM Replacement: passo 5, immagine 2 di 3 Gateway NV55C49u RAM Replacement: passo 5, immagine 3 di 3
    • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
  6. Gateway NV55C49u RAM Replacement: passo 6, immagine 1 di 2 Gateway NV55C49u RAM Replacement: passo 6, immagine 2 di 2
    • Hold back the plastic that protects the RAM so you can access the clips underneath.
    • Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Gently remove the RAM from the laptop
    • Make sure not to touch any part of the RAM except the sides.
    • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 254
