Salta al contenuto principale
Gateway NV55C49u Battery Replacement
Cosa ti serve
  1. Gateway NV55C49u Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Battery Replacement: passo 2, immagine 1 di 1
    • Switch the battery lock to show a red background with an unlock symbol
  3. Gateway NV55C49u Battery Replacement: passo 3, immagine 1 di 2 Gateway NV55C49u Battery Replacement: passo 3, immagine 2 di 2
    • Flip the switch with the battery symbol on it.
    • The battery should eject if done correctly.
  4. Gateway NV55C49u Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery by lifting the battery out.
  5. Gateway NV55C49u Battery Replacement: passo 5, immagine 1 di 1
    • This battery contains harmful chemicals, so it must be disposed of properly. Please take the old battery to a waste disposal center or recycling center.
    • Tip: in France, you can dispose of the old battery in the battery disposal points that can be found in a lot of supermarkets.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 332
