Salta al contenuto principale
Gateway NV53A24u Keyboard Replacement
Cosa ti serve
  1. Gateway NV53A24u Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Before removing the keyboard, turn off the computer and open it.
  2. Gateway NV53A24u Keyboard Replacement: passo 2, immagine 1 di 2 Gateway NV53A24u Keyboard Replacement: passo 2, immagine 2 di 2
    • Use a spudger to gently pry out the keyboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
    • There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
  3. Gateway NV53A24u Keyboard Replacement: passo 3, immagine 1 di 2 Gateway NV53A24u Keyboard Replacement: passo 3, immagine 2 di 2
    • Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
Conclusione
tannerroan
Membro da: 10/11/16
339 Reputazione
2 Guide realizzate
USF Tampa, Team 1-5, Leahy Fall 2016 Membro di USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 650
