Salta al contenuto principale
Gateway NV52 Hard Drive Replacement
Cosa ti serve
  1. Gateway NV52 Hard Drive Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: passo 3, immagine 1 di 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Replacement: passo 4, immagine 1 di 3 Gateway NV52 Hard Drive Replacement: passo 4, immagine 2 di 3 Gateway NV52 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
  5. Gateway NV52 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
  6. Gateway NV52 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
Conclusione
Irma Marin
Membro da: 04/10/14
605 Reputazione
3 Guide realizzate
Cal Poly, Team 7-24, Regan Spring 2014 Membro di Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,404
