Salta al contenuto principale
Gateway NV52 Hard Drive Compartment Replacement
Cosa ti serve
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: passo 1, immagine 1 di 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: passo 2, immagine 1 di 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: passo 3, immagine 1 di 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: passo 4, immagine 1 di 3 Gateway NV52 Hard Drive Compartment Replacement: passo 4, immagine 2 di 3 Gateway NV52 Hard Drive Compartment Replacement: passo 4, immagine 3 di 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
Conclusione
Altre 2 persone hanno completato questa guida.
Tim En
Membro da: 01/26/13
557 Reputazione
4 Guide realizzate
Cal Poly, Team 7-24, Regan Spring 2014 Membro di Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 982
