Salta al contenuto principale
Gateway NE56R27u Keyboard Replacement
Cosa ti serve
  1. Gateway NE56R27u Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Keyboard Replacement: passo 2, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement: passo 2, immagine 2 di 2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, immagine 1 di 3 Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, immagine 2 di 3 Gateway NE56R27u Keyboard Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Keyboard Replacement: passo 4, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement: passo 4, immagine 2 di 2
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Keyboard Replacement: passo 5, immagine 1 di 3 Gateway NE56R27u Keyboard Replacement: passo 5, immagine 2 di 3 Gateway NE56R27u Keyboard Replacement: passo 5, immagine 3 di 3
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Keyboard Replacement: passo 6, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement: passo 6, immagine 2 di 2
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Keyboard Replacement, Keyboard: passo 7, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement, Keyboard: passo 7, immagine 2 di 2
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Keyboard Replacement: passo 8, immagine 1 di 2 Gateway NE56R27u Keyboard Replacement: passo 8, immagine 2 di 2
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Keyboard Replacement: passo 9, immagine 1 di 3 Gateway NE56R27u Keyboard Replacement: passo 9, immagine 2 di 3 Gateway NE56R27u Keyboard Replacement: passo 9, immagine 3 di 3
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 581
