Salta al contenuto principale
Gateway NE52214U Hard Drive Replacement
Cosa ti serve
  1. Gateway NE52214U Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Make sure that your laptop is powered down and turned off.
    • Flip the laptop over so the backside is facing you.
    • Remove the three 7mm screws using the Phillips #1 screwdriver.
  2. Gateway NE52214U Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the compartment cover up.
  3. Gateway NE52214U Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the hard drive from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 163
