Salta al contenuto principale
Gateway NE52203u Wireless Card Replacement
Cosa ti serve
  1. Gateway NE52203u Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u Wireless Card Replacement: passo 2, immagine 1 di 2 Gateway NE52203u Wireless Card Replacement: passo 2, immagine 2 di 2
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u Wireless Card Replacement: passo 3, immagine 1 di 1
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: passo 4, immagine 1 di 2 Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: passo 4, immagine 2 di 2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u Wireless Card Replacement: passo 5, immagine 1 di 1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u Wireless Card Replacement: passo 6, immagine 1 di 2 Gateway NE52203u Wireless Card Replacement: passo 6, immagine 2 di 2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u Wireless Card Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u Wireless Card Replacement: passo 8, immagine 1 di 3 Gateway NE52203u Wireless Card Replacement: passo 8, immagine 2 di 3 Gateway NE52203u Wireless Card Replacement: passo 8, immagine 3 di 3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u Wireless Card Replacement, Wireless Card: passo 9, immagine 1 di 2 Gateway NE52203u Wireless Card Replacement, Wireless Card: passo 9, immagine 2 di 2
    • Grab the antenna cable with tweezers and lift up to pull it off.
    • The antenna is the small black cable with the golden head
  10. Gateway NE52203u Wireless Card Replacement: passo 10, immagine 1 di 1
    • Remove the one 2.9 mm Phillips #00 screw holding down the wireless card in place.
  11. Gateway NE52203u Wireless Card Replacement: passo 11, immagine 1 di 1
    • After the screw is removed, the card will spring upwards slightly. Pull out the old wireless card from its port.
Conclusione
Stephen Spees
Membro da: 03/20/15
542 Reputazione
4 Guide realizzate
Baylor, Team 2-1, Grigsby Spring 2015 Membro di Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 706
