Salta al contenuto principale
  1. Ensure device is powered off and unplugged from a power source. Place the device upside down.
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  4. Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  5. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  6. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 80
