Salta al contenuto principale
Gateway NE51006u Battery Replacement
Cosa ti serve
  1. Gateway NE51006u Battery Replacement, Battery: passo 1, immagine 1 di 2 Gateway NE51006u Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your device is powered off before beginning this guide.
    • Place your device on your workspace, screen facing down. Take the Spudger and use the pointed end to catch the latch below the battery. Drag the latch to the right until the battery detaches from the body of the device.
  2. Gateway NE51006u Battery Replacement: passo 2, immagine 1 di 1
    • Pull the battery out, making sure to pull the battery parallel to the device.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 719
