Salta al contenuto principale
Gateway MS2370 Screen Replacement
Cosa ti serve
  1. Gateway MS2370 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: passo 2, immagine 1 di 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: passo 5, immagine 1 di 2 Gateway MS2370 Screen Replacement: passo 5, immagine 2 di 2
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: passo 6, immagine 1 di 1
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: passo 7, immagine 1 di 1
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: passo 8, immagine 1 di 1
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: passo 9, immagine 1 di 3 Gateway MS2370 Screen Replacement: passo 9, immagine 2 di 3 Gateway MS2370 Screen Replacement: passo 9, immagine 3 di 3
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: passo 10, immagine 1 di 2 Gateway MS2370 Screen Replacement: passo 10, immagine 2 di 2
    • Slowly remove the screen from the laptop.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 804
