Salta al contenuto principale
Gateway MS2370 Keyboard Replacement
Cosa ti serve
  1. Gateway MS2370 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Keyboard Replacement: passo 2, immagine 1 di 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
  5. Gateway MS2370 Keyboard Replacement: passo 5, immagine 1 di 1
    • Carefully lift the keyboard molding out.
  6. Gateway MS2370 Keyboard Replacement: passo 6, immagine 1 di 1
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
  7. Gateway MS2370 Keyboard Replacement: passo 7, immagine 1 di 1
    • Slowly lift the keyboard from the laptop.
  8. Gateway MS2370 Keyboard Replacement: passo 8, immagine 1 di 2 Gateway MS2370 Keyboard Replacement: passo 8, immagine 2 di 2
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
  9. Gateway MS2370 Keyboard Replacement: passo 9, immagine 1 di 1
    • Lift and remove the keyboard from the computer.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,009
