Salta al contenuto principale
Gateway MS2285 Hard Drive Replacement
Cosa ti serve
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: passo 1, immagine 1 di 1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: passo 2, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: passo 2, immagine 2 di 2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: passo 3, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Release The Battery: passo 3, immagine 2 di 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: passo 4, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Remove The Battery: passo 4, immagine 2 di 2
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: passo 5, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: passo 5, immagine 2 di 2
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, immagine 1 di 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, immagine 2 di 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, immagine 3 di 3
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: passo 7, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: passo 7, immagine 2 di 2
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: passo 8, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: passo 8, immagine 2 di 2
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, immagine 1 di 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, immagine 2 di 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, immagine 3 di 3
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: passo 10, immagine 1 di 2 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: passo 10, immagine 2 di 2
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Conclusione
Chris mello
Membro da: 10/22/14
331 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Membro di UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,682
