Salta al contenuto principale
Gateway MD2614u Wireless Card Replacement
Cosa ti serve
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Wireless Card Replacement: passo 2, immagine 1 di 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Wireless Card Replacement: passo 3, immagine 1 di 1
    • Lift off the cover.
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • The wireless card is located to the right of the hard drive and below the RAM.
  5. Gateway MD2614u Wireless Card Replacement: passo 5, immagine 1 di 1
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
  6. Gateway MD2614u Wireless Card Replacement: passo 6, immagine 1 di 1
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
  7. Gateway MD2614u Wireless Card Replacement: passo 7, immagine 1 di 1
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
Conclusione
Toni Pipes
Membro da: 10/05/10
333 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,329
