Salta al contenuto principale
Gateway MD2614u RAM Replacement
Cosa ti serve
  1. Gateway MD2614u RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u RAM Replacement: passo 2, immagine 1 di 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u RAM Replacement: passo 3, immagine 1 di 1
    • Lift off the cover.
  4. Gateway MD2614u RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Identify the RAM, which is a stack of two green cards in the upper left-hand corner.
  5. Gateway MD2614u RAM Replacement: passo 5, immagine 1 di 1
    • There are silver tabs on both sides of the ram. Simultaneously push the silver tabs outward.
  6. Gateway MD2614u RAM Replacement: passo 6, immagine 1 di 1
    • The card pops up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card to the right horizontally.
  7. Gateway MD2614u RAM Replacement: passo 7, immagine 1 di 1
    • Follow the same steps for the second RAM card, which is under the one you just removed.
Conclusione
Toni Pipes
Membro da: 10/05/10
333 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,351
