Salta al contenuto principale
Gateway MD2614u Processor Replacement
Cosa ti serve
  1. Gateway MD2614u Processor Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: passo 2, immagine 1 di 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: passo 3, immagine 1 di 1
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: passo 4, immagine 1 di 1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: passo 5, immagine 1 di 1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: passo 6, immagine 1 di 1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: passo 7, immagine 1 di 1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Compra
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: passo 9, immagine 1 di 1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Conclusione
Altre 2 persone hanno completato questa guida.
Toni Pipes
Membro da: 10/05/10
333 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
14 Guide realizzate
Un commento
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 7,170
