Salta al contenuto principale
Gateway MD2614u Internal Modem Replacement
Cosa ti serve
  1. Gateway MD2614u Internal Modem Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Internal Modem Replacement: passo 2, immagine 1 di 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Internal Modem Replacement: passo 3, immagine 1 di 1
    • Lift off the cover.
  4. Gateway MD2614u Internal Modem Replacement, Internal Modem: passo 4, immagine 1 di 1
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  5. Gateway MD2614u Internal Modem Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  6. Gateway MD2614u Internal Modem Replacement: passo 6, immagine 1 di 1
    • Carefully pry the modem as to not damage any of the surrounding components
  7. Gateway MD2614u Internal Modem Replacement: passo 7, immagine 1 di 1
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  8. Gateway MD2614u Internal Modem Replacement: passo 8, immagine 1 di 1
    • Success! You've removed the internal modem!
Conclusione
Nelson
Membro da: 03/11/14
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 378
