Salta al contenuto principale
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: passo 2, immagine 1 di 1
    • Slide and hold the battery release lock to the left.
  3. Gateway MD2614u Battery Replacement: passo 3, immagine 1 di 1
    • Pull the battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: passo 4, immagine 1 di 1
    • Insert the new battery into the slot.
Conclusione
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
Membro da: 10/05/10
333 Reputazione
7 Guide realizzate
Cal Poly, Team 21-31, Regan Fall 2010 Membro di Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,917
