Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
More Random Access Memory (RAM) allows the laptop to run more programs simultaneously, and speed up certain processes. The Gateway MA 7 takes PC2-4200 DDR2 533Mhz 200PIN SODIMM RAM.
Strumenti
Nessun attrezzo specificato.
  1. To prevent injury, make sure the laptop is unplugged before removing the battery.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while pulling out the battery.
  2. Remove the following screws securing the plastic panel from the bottom of the laptop: Seven 6 mm Phillips #0
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Seven 6 mm Phillips #0
  3. Pull upwards on the top of the plastic panel to remove it. With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece. With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Push the two metal tabs (holding the module in place) apart in order to release it. Push the two metal tabs (holding the module in place) apart in order to release it.
    • Push the two metal tabs (holding the module in place) apart in order to release it.
  5. Pull the ram out of the motherboard at a 45 degree angle. Pull the ram out of the motherboard at a 45 degree angle.
    • Pull the ram out of the motherboard at a 45 degree angle.
  6. Repeat steps 4 & 5 for the other memory module. Repeat steps 4 & 5 for the other memory module. Repeat steps 4 & 5 for the other memory module.
    • Repeat steps 4 & 5 for the other memory module.
Conclusione
Altre 2 persone hanno completato questa guida.
Tim Rose
Membro da: 05/03/2018
392 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 389
