Salta al contenuto principale
Gateway MA7 CD/DVD Drive Replacement
Cosa ti serve
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: passo 2, immagine 1 di 2 Gateway MA7 CD/DVD Drive Replacement: passo 2, immagine 2 di 2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: passo 3, immagine 1 di 3 Gateway MA7 CD/DVD Drive Replacement: passo 3, immagine 2 di 3 Gateway MA7 CD/DVD Drive Replacement: passo 3, immagine 3 di 3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: passo 4, immagine 1 di 2 Gateway MA7 CD/DVD Drive Replacement: passo 4, immagine 2 di 2
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: passo 5, immagine 1 di 1
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: passo 6, immagine 1 di 3 Gateway MA7 CD/DVD Drive Replacement: passo 6, immagine 2 di 3 Gateway MA7 CD/DVD Drive Replacement: passo 6, immagine 3 di 3
    • Once the drive has been pried out, you can pull the CD drive out.
Conclusione
Tim Rose
Membro da: 03/05/18
392 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 477
