Salta al contenuto principale
Gateway MA6 Laptop Wireless Card Replacement
Cosa ti serve
  1. Gateway MA6 Laptop Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Wireless Card Replacement: passo 2, immagine 1 di 3 Gateway MA6 Laptop Wireless Card Replacement: passo 2, immagine 2 di 3 Gateway MA6 Laptop Wireless Card Replacement: passo 2, immagine 3 di 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 2 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: passo 3, immagine 2 di 2
    • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
    • The screw will remain in the backplate.
    • Lift upwards on the back plate to remove it.
  4. Gateway MA6 Laptop Wireless Card Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
  5. Gateway MA6 Laptop Wireless Card Replacement: passo 5, immagine 1 di 1
    • Remove the 2 mm Phillips #0 screw.
    • The card will lift itself up 30° after the screw has been removed.
  6. Gateway MA6 Laptop Wireless Card Replacement: passo 6, immagine 1 di 2 Gateway MA6 Laptop Wireless Card Replacement: passo 6, immagine 2 di 2
    • Hold the WiFi card on both sides and pull outwards to remove it.
Conclusione
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 708
